help with my carburetor
Old Jul 1, 2010 | 07:25 PM
flynnallthetime's Avatar
Car: 1987 firebird
Engine: v8 5.0L 305=]
Transmission: stock=/
Axle/Gears: stock=/
hey guys. i just got a new 600 cfm edelbrock carburetor for my 87 base firebird .v8 305. and i want to jet it up as much as i can so i can get more horsepower/ i was wondering if any one has videos on how to do it or if u can explain it to me thank you
Old Jul 1, 2010 | 08:27 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: help with my carburetor
My guess is that your carb is already supplying too much fuel for your car. I remember my Edelbrock being way too rich out of the box. More fuel will only make more power if your engine can use it. Too much fuel will kill horsepower, gas mileage, spark plugs and piston rings.
Old Jul 1, 2010 | 08:41 PM
Car: 1987 firebird
Axle/Gears: stock=/
how do i know if its giving to much fuel or not? and what could i add to the engine/exaust for more hp? very much apperciatred
Old Jul 1, 2010 | 09:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Look up ^^^^^ There is a sticky for Edelbrock carbs - the manual is there, as well as some nice videos that explain tuning on them.
Old Jul 1, 2010 | 09:12 PM
Car: 1987 firebird
Axle/Gears: stock=/
thank you very much. i didnt think to look for one
Old Jul 6, 2010 | 07:11 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
If you got the Edelbrock 1406 it is generally a little lean out of the box for a 305. I have a slightly better cam than stock and I recently put in .101 secodary jets and bumped up to the next richer setting on the primaries with a rod change. This is working out quite well for me.
A jet and rod kit is available for around $35. It has everything you really need. The manual is kind of confusing. If you are only a little mechanically inclined you can take the top ("air horn") off the carb and everything is easily accessed. The manual made a lot more sense to me after I took the carb apart the first time. These carbs are extremely simple.
85cmroz28
Oct 4, 2015 09:44 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
