Q-jet with Supercharger
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Q-jet with Supercharger
Judging by your lack of responses on this thread, and others, i'd guess no.
Pressurizing a q-jet isn't very common. GM factory used a q-jet with a draw through setup on the turbo Firebirds in 1981, but never blow-through.
People have modified q-jets to accept blow through, but it's tricky. Different float, modified throttle shaft generally, marine accelerator pump, sealing the air intake to the carb air intake, etc...
Car: 1982 Trans-Am
uh, a q-jet is an excellent street carb, with great gas mileage.
Or did you mean with a blow-through setup? If you're planning on blowing through a carb, just forget fuel mileage altogether, that's a pipe-dream.
Get a dedicated blow through carb.
Car: 1984 Berlinetta
Axle/Gears: 3.08
I know I'm not going to get the best but This is my Daily.
toronto formula
Nov 10, 2015 06:17 AM
aircraft, blow, blowthrough, carb, carbs, gas, jet, milage, qjet, set, setting, setup, supercharged, supercharger, tech
