Rochester Electric Choke Question
Old Aug 9, 2010 | 08:46 AM
srgould41's Avatar
I am building up my truck and have not started the engine yet. I installed a Rochester 4bbl Quadrajet. Someone modified the hot air choke with an electric one instead. I wanted to verify that it worked so I plugged 12v into it. After about 5 minutes (occasionally opening the throttle) nothing happened.
I put a multi-meter on the power tang then to a good ground on the engine and read infinite resistance. I should have grounded it to the carb body to be certain, however. I'll try that next.
Anyway, what should I be seeing for resistance across the heater coil?
Thanks,
Steve
Old Aug 9, 2010 | 09:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Rochester Electric Choke Question
I don't remember what a typical value is, but it's a lot less than infinite.
MustangBeater20
Oct 29, 2022 09:20 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
lakeffect2
Aug 23, 2015 08:44 AM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
