fired my engine may have carb problems?
Old Aug 14, 2010 | 09:43 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
finally fired the engine in my other toy (67 c-10) i have a "880" block 062 heads and an lt1 cam crosswind intake and an edlebrock 1405. base timing set at 12 BTDC. it starts right up and idles nice, punch it from idle and it backfires through the carb. at steady throttle cruising it seems sluggish. im running a holley electric pump(old) with a vane and rotor kit installed and a holley regulator with a new diaphragm kit. fuel pressure set at 5psi (most i can get out of the pump?) after running for a few minutes the fuel pressure drops to 2.5-3 psi and unresponsive to regulator adjustments? also im running a new ebay hei/procomp wire kit. thanks
Old Aug 16, 2010 | 02:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
re: fired my engine may have carb problems?
Make sure the firing order is correct. Make sure all plug wires are fully 'snapped' on the plugs and dist. Test the plug wires for continuity (I've bought many bad plug wires that were 'new'). Are you sure you stabbed the dist at TDC on the compression stroke?
Old Aug 17, 2010 | 02:08 PM
Re: fired my engine may have carb problems?
yup distributor is tdc on compression, starts and idles like a dream, stomp the gas and i get a pop through the carb
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
