e4me carb on 85 v8
Car: 1985 Chevrolet Camaro
Engine: V8 lb9 i believe..
Axle/Gears: 10 bolt posi
e4me carb on 85 v8
I have a 85 camaro with a v8 and long ago when i first bought the car it ran great, it was fast and smooth. one day the i was driving and my car backfired and it would not accelerate anymore. it would idle, and it would move when i tapped the gas, but a consistent depression on the pedal yielded no results.
i bought a carb from autozone and the guy said it was the right one. i bolted it up and noticed that the electrical connectors didnt have a spot to connect to. i reslized that this was the wrong carb. i already had it hooked up and flowing. the car still started up and ran, but much much crappier and slower.
it was my only car and i needed to get to work
well recently i purchased a used e4me from someone and i have tha hooked up and the electrical connectors hooked up as well. but, since ive removed the old carb and ive had the non cc carb, ive forgotten where all the vaccum lines go. and the car isnt running or starting well at all.
advice and pictures if you have them will be greatly appreciated.
Re: e4me carb on 85 v8
any ideas on what i can cap off on the carb that is used by the smog system?
which one are and are not necessary?
Car: '91 Firebird
Engine: LO3 305 TBI
Transmission: TH700R4
Axle/Gears: 10 bolt 2.73 gears
Get a service manual and it will have all the diagrams for emissions equipment routing and all that. I had mine laying open next to me while I hooked everything back up on mine. Much easier that way.
i think i still have the sticker in place. if i do ill take a picture and post it.
I took a look under the hood. and the emissions sticker is gone. ive since capped off the two ports that had no home on the carb. i wont have the time to run her up and try more things til next week.
Car: 84 Firebird, 78 Trans Am
Engine: LG4 305 Qjet, Pontiac 400cid
Transmission: T5 Non WC, TH350
Axle/Gears: All stock
Not sure if this will help, but if your Camaro has an LG4 305, then I'm pretty sure the emissions diagram is identical to a 85 Firebird with the LG4 305.
I redrew this 84 LG4 emissions diagram using photshop and comparing the diagram under my hood with the one in my Chilton; the only difference I saw between 84 and 85 was a plastic little check valve near the AIR tubes.
Vac Diagram
Vac Diagram
ok so really only the ports marked in the diagram as N, L, T, and H need to be hooked up. ill get in there and fiddle around and see what i get out of it. thanks alot
i dont have the original air cleaner, so i dont have anywhere to connect the J port. and i dont have the EGR system functional.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The CC carb without a functioning EGR won't ever run right. Best just to disconnect the lines, get an old HEI vacuum distributor and use the carb you bought from autozone if you aren't willing to hook it back up.
Transmission: 4L80E/4L80E
Funny, mine ran fine for 4 years without an EGR valve. Had to have the solenoid hooked up to keep it from turning on the SES light, but it ran fine.
By the way, there's a thread on the FAQ forum with vacuum diagrams in it.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Neither would light the SES with an EGR code when it was disconnected. Probably different ECM versions.
Random pic:
Hinges-Ball Bearing, Non-Removable Pins, US 32D Finish, Hager ECBB1101 4 ½ x 4 ½.
Wait that was a hardware spec.
Here:
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
