Carb
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Carb
Also, if you look Here you will find some info on this subject that I believe will be related to what you are going through.
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: Carb
Sounds like the accelorator pump could be bad. Try a full on rebuild. because if you romp it at the carb it reves but with the foot inside the car you kinda have less control.
Transmission: 4L80E/4L80E
What air cleaner do you have on it?
Where is your timing set?
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
