Electric v. Mechanical Fuel Pump
Old Oct 7, 2010 | 12:21 AM
Seri's Avatar
Car: 91 Camaro
Engine: 396
Transmission: TH-400
Axle/Gears: 3.70
Ok i know this is a debate but i'm tring to figure out if a mechanical fuel pump will feed my engine or if i will have to go with an electric fuel pump. I'm tring to stay away from electric as much as i can.
396 w/ 871 blower
duel 4b holley 750 (is what is planned)
Holley also says that a regulator per carb is suggested but i've never seen or used that set up before and tring to figure how that would run and just see a snake bed for fuel lines. This will be my first duel carb set up so tring to figure it out as i go.
Old Oct 7, 2010 | 12:47 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Electric v. Mechanical Fuel Pump
Either type of pump of appropriate volume on a fuel system of adequate size should work.
Old Oct 9, 2010 | 01:17 PM
Seri's Avatar
Car: 91 Camaro
Engine: 396
Axle/Gears: 3.70
ok..ty and on the the 2nd part of the question...anyone have a pic of what a duel carb set up should look like for the regulator? Never seen 1 per carb before so if anyone has a duel carb set up let me know. Thanks.
Old Oct 11, 2010 | 03:52 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
you would need a good mechanical pump for that big of a blower. As long as it can flow enough then mechanical should be fine
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
