Rich or Lean
Old Oct 7, 2010 | 03:29 PM
Allamericantc's Avatar
Car: 87 TA
Engine: 355
Rich or Lean
Hey Guys,
Sorry in advance for my question, however, I am not too experienced with carbs. Just put on a 650 and I can get her to run and idle with some help. When i get it on the road A) it will backfire on me quite a bit, B) the emissions are terrible, C) the last time I turned the key off, it remained running for a second or two, almost as if it was still getting fuel. Whats the deal with making it Lean vs Rich and how to I do that. I have a Carter carb, pretty much the same thing as an edelbrock. What are the two screws on the front of my carb? Is that how I adjust the A/F mix?
Thanks so much
Old Oct 8, 2010 | 06:46 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: Rich or Lean
I can't help with the Carter Carb, but what about your timing setup? It sounds like you may have the timing retarded. Where is the initial set?
Old Oct 8, 2010 | 08:13 AM
Car: 87 TA
Engine: 355
Re: Rich or Lean
I set it TDC at 0 degrees... I really don't know much about Carb's so I'm really struggling.
Old Oct 8, 2010 | 10:01 AM
pancherj's Avatar
Car: 1990 IROC
Re: Rich or Lean
That could be your problem. You want about 10 degrees of advance at idle. Tell us what distributor you are using and exactly how your are setting/checking the timing.
Old Oct 8, 2010 | 02:11 PM
Car: 87 TA
Engine: 355
Re: Rich or Lean
I adjusted the mixture screws and seems to have really calmed it down a bunch and its idling and driving nicely. I will go ahead this weekend and adjust to 10 degrees TDC and see what that does for me.
Thanks!!
Old Oct 8, 2010 | 02:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's 10 degrees BTDC at idle with the vacuum advance disconnected.
You do have a vacuum/mechanical advance distributor, right?
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
Jk_Under
Sep 8, 2015 08:13 AM
