Carb Gas line switch?????? help.
Car: 1989 Formula Firebird
Engine: 355 w/ 750 demon
Transmission: 700r4 / 2000 stall
So im swapping from a 305 tbi to a 355 with demon 750 carb into my 1989 formula firebird. Im going with a on the block fuel pump. since it came with a tbi there are 2 gas lines coming from the tank up to the engine bay. One i know is a return line. But which line is which? which one is the return line? and do i need to block that one off since im going with a on the block fuel pump and just use the inlet? how do i go about this? thanks.
Car: 84 Firebird, 78 Trans Am
Engine: LG4 305 Qjet, Pontiac 400cid
Transmission: T5 Non WC, TH350
Axle/Gears: All stock
Re: Carb Gas line switch?????? help.
On my mechanical engine-based fuel pump, 1. the smaller connector is the return line; 2. the larger is the actual fuel line from tank to pump and 3. the inlet is for pump-to-carburetor.
Transmission: 4L80E/4L80E
Yes i am. to get rid of the electric one. but which one in the engine bay is the return line. there both the same size? and i don't need the return line as i am puting a mechanical pump on? Correct?
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
If you check on the driver side under the hood were the the three steel lines come from the tank, ull have one that goes to the canister on the front then two that go to the TBI, the thicker one is the feed line the thinner tube is the return. Hope that clears up your doubt
yes that clears it up. thanks you. And i can completely get rid of the return line correct?
Engine: 305 TBI L03
Using a return line helps reduce or eliminate vapor lock. But, so does using an in-tank electric pump.
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
