this a good air intake system??
Car: 1985 Pontiac Trans AM
Engine: 5.0
Transmission: t-5WC
Axle/Gears: 3.23 open diff.
wondering if a set up like this would be better then the dual snorkle air cleaner.I have enough space to run a filter down in front of both sides of the radiator pointing down so it sucks in cold air.is this a good system?
http://www.summitracing.com/parts/SPE-761/
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: this a good air intake system??
they have a cold air kit I saw on horsepower a couple week ago that has the heat shields and everything only problem i saw was you would have to move the battery and charcol canister .
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's pretty, but at $120 + shipping, that's about $360 per horsepower gain over whatever you currently have (in otherwords, you might get an extra 1/3 hp out of it). I'm all for pretty, if your wallet allows for it go for it - just know you'll get no noticeable gain.
Car: 1990 Camaro ZRS
Engine: 350 SBC
if he orders it from summit, shipping will be free. he would only pay for taxes. and if u have a stock hood, u may need to check for clearance. i know spectre has a lower profile one very similar that a guy made on here.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Transmission: 4L80E/4L80E
It'll be better than an open element, not quite as good as a true cold air system. If you already have a dual snorkel set-up, I'd keep it. If you don't, this one won't cost you any more than a factory dual snorkel, that's for sure.
Car: 87 Camaro
Engine: 305 LG4 (H)
But the stock setup is pretty much a true cold air system. Not to mention that one posted looks like cheap garbage, and (this is my opinion only) its truly a fugly piece.
I had the Spectre single snorkel, non-dropped hat, filter housing, and ducts on the '57 for a couple of years. It's hardly "cheap garbage".
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
1985, air, camaro, carberator, gen, generation, housing, intake, lg4, spectre, system, systemthird, trans
