charcoal canister
Old Nov 2, 2010 | 04:53 PM
j.prince428's Avatar
Car: 1983 Z28
Engine: 5.7
Axle/Gears: UNKNOWN
charcoal canister
Hello everyone. I have an 83 z28 and I'm replacing my emissions controlled carbureted intake system with a holly street avenger and performer intake. I'm getting rid of the egr, smog pump, and all the other related emissions parts. I'm not sure about the charcoal canister in the front of the car. I think it vents the gas tank and carb but I'm not sure. Should I keep the canister or get rid of it? Also I have a LOT of extra wires that will not have anything to plug in to once the swap is complete. Many come off of the carb and intake and many of the old emissions parts. Do most of these run back to the computer and is it safe to just rip out the computer along with the wires that will not be re used? Any help is greatly appreciated.
Old Nov 2, 2010 | 05:41 PM
nate perron's Avatar
Car: 83 berlinetta
Engine: 305 roller motor
Transmission: th350
Axle/Gears: 10 bolt 3.08
Re: charcoal canister
well there is a lot of factors to consider when answering your question.
for starters does your state or area emissions test vehicles?
if so you must have your smog equipment present on the car.
also some states do not test emissions but do inspect your car for the equipment that has been federaly mandated since 1975.
things like catylitic converters and such. I have heard of people getting pulled over by law enforcement for traffic infractions and the officer looking under the car for the said converter. so be fore warned if you remove some thing you might regret it later. I myself have removed every thing exept the cat and been able to pass emissions. so do some checking about your peticular state and find out for sure.
Old Nov 2, 2010 | 06:38 PM
Car: 1983 Z28
Engine: 5.7
Axle/Gears: UNKNOWN
Well I live in Maryland and my car is registered as historic so I am exempt from emissions laws. The first step in my conversion was making sure I don't need to worry about that anymore.
Old Nov 8, 2010 | 12:08 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
i removed the egr and cat and any antipollution stuff...but i got the canister hooked up so it takes the gas fumes from the tank,,,
Old Nov 8, 2010 | 01:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Any particular reason why?
Quzyle
Oct 15, 2015 03:35 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
TBRays98
Sep 6, 2015 05:05 PM
