fuel pump to use after carb swap
I am still running the tpi fuel pump. Can I just change the pump in the tank to a lesser psi pump. Or just use an in line pump and and figure out what wire to disconnect to provide power to the pump. Any suggestions would be great thanks
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: fuel pump to use after carb swap
Get ahold of
zeek
He has it for $100.
Mallory 4309 part #!!!
zeek
He has it for $100.
Car: '87 Camaro
This fuel pressure regulator is what you can use without dropping the tank.
Transmission: 4L80E/4L80E
The TPI pump is fine when used with a return-type regulator such as the Mallory 4309.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
