low fuel pressure
Old Nov 24, 2010 | 09:01 PM
marine68's Avatar
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
low fuel pressure
i need some opinions on how to resolve this problem, i have the red holley elec fuel pump,7 psi and the holley 803bp regulator installed with 3/8 inch fuel and fuel return lines. the problem is that i can't adjust the regulator past 4 psi. is that too low for the engine. i hate to remove the recently install regulator, new fuel,return lines. can i just remove the spring from the regulator to get 6 psi or more.
Old Nov 24, 2010 | 09:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: low fuel pressure
Carbs aren't really dependent on fuel pressure like an EFI system, despite what alot of people think. As long as the pump is keeping the fuel bowls adequately full, then pressure isn't really an issue. So if you aren't starving the motor for fuel, I wouldn't worry about the fuel pressure.
Old Nov 24, 2010 | 09:26 PM
marine68's Avatar
Car: 89 IROC Z28
thanks so then i keep everything the way it is and don't worry about the pressure
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
