My delco carb: Question: pic inside
Old Nov 25, 2010 | 10:41 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
Hello
how are you
first let me tell you i dont know much about engines.
i recently bought 84 T/A and i was just about this carb. I noticed that this door in the pic. always stay fully open all the time even if the car is not running .
just wanted to know if that's normal?
thank you for your help
Old Nov 25, 2010 | 10:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: My delco carb: Question: pic inside
Open the throttle with the engine cold and see if it closes.
Old Nov 25, 2010 | 11:15 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
Thanks i will try that tomorrow. so that door should be opening and closing right?
Old Nov 26, 2010 | 08:30 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the choke plate. When the throttle is closed, it'll stay trapped in whatever position its in. If everything works then when the throttle opens, it'll want to be shut if the engine is cold, and open within a few minutes of starting.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Fronzizzle
Sep 8, 2015 12:10 PM
lakeffect2
Sep 7, 2015 03:52 PM
