carb cfm
Old Feb 20, 2011 | 03:35 PM
j.prince428's Avatar
Car: 1983 Z28
Engine: 5.7
Axle/Gears: UNKNOWN
carb cfm
I know this is a dumb question but what is the cfm of the carb on my 83 z28?
Old Feb 20, 2011 | 04:28 PM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
Re: carb cfm
If it's the factory quadrajet it should be 750cfm i think
Old Feb 21, 2011 | 12:34 AM
DoubleV's Avatar
Re: carb cfm
All CCC carbs are 800cfm with the secondary air valve limited on some models not to open fully, thus reducing the max cfm it can flow. Grinding off the tang limiting the air valve travel, instant 800 cfm.
Old Feb 21, 2011 | 11:49 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: carb cfm
All factory Quadrajets on small blocks, CC or otherwise, are 795cfm. There are a few 850cfm units, but those only came on the big motors like some 454s and Caddy 500s.
That said, SOME had a little tab under the air doors that limit how much they will open, and cut cfm down to about 600cfm. Aside from the tabs, the carbs are still the same.
Old Feb 21, 2011 | 03:37 PM
DoubleV's Avatar
Re: carb cfm
I think you're off by about 50 cfm. All qjets are rated at either 750 or 800 cfm. Maybe the actual flow is different, but 750/800 are what they are rated at.
okfoz
Oct 13, 2015 02:19 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
lanceflame44
Sep 25, 2015 12:28 PM
