Fuel Level Sender Interchange
Old Mar 10, 2011 | 11:24 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Today i was at the junkyard and found a nice fuel sender, but it had an in tank pump. My 1982 Camaro is a Carbed. The Pump is on the Engine. Since there are about 3 years that have that setup, It's harder to find that sender. Can i use one from a Caprice, For Example, to replace the one in my Car? If not, are there any other cars/trucks that DO have what i need?
Old Mar 14, 2011 | 03:46 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Fuel Level Sender Interchange
You can get one from a later model Fbody that had fuel injection, but you may need to run a piece of fuel line to make the newer sender longer to match the length of your original stock one because you need to account for the electric fuel pump which these are made for that you don't need. Of course, you could install an electric fuel pump, wire it up and use it as a pusher..or stand alone bypassing the mechanical pump all together which is what I did on my 84.
Old Mar 14, 2011 | 06:46 PM
383 Power's Avatar
So, what you're saying is that there is a way to use the newer style sender and retain my present fuel delivery system?
Old Mar 14, 2011 | 07:39 PM
Wiggles's Avatar
Car: 84 Firebird, 78 Trans Am
Engine: LG4 305 Qjet, Pontiac 400cid
Transmission: T5 Non WC, TH350
Axle/Gears: All stock
I ran into the same issue on my 84 since the fuel sending unit was nearly disintegrated with rust and decay. Didn't do it myself since I have no hydraulic lift and the exhaust had to be cut but the boys down at the shop were able to do it. They used a sending unit for an 85 fuel injected model and where the in-tank pump was, they attached an extended stainless steel pickup tube with a compression fitting. Works fine.
The sticky at the top of the page -> https://www.thirdgen.org/forums/carb...nk-pickup.html actually makes sense to me. This is practically what they did to mine, only he went with an external electric pump; I kept my old fashioned mechanical pump.
Old Mar 15, 2011 | 03:11 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Yes, very simple actually, with a little bit of modification. Previous poster answered how to do it and the sticky will help some. It'll really make sense if/when you pull the old sender out and compare it to a newer fuel injected model. You'll see the difference and what you'll have to do.
Old Mar 15, 2011 | 12:05 PM
383 Power's Avatar
thank you very much! So, Then, i could even get a Sender from a 4th gen and make it work? This seems very liberating.
Old Mar 15, 2011 | 12:45 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
As far as i know, the 4th gen senders dont work with a 3rd gen tank, the tank openeings are different sizes and have a different way to secure it. (unless that just happened on the tank i pulled out of the jyard not too long ago.)
Old Mar 15, 2011 | 02:06 PM
Ozz1967's Avatar
Car: 1984 Trans Am
4th gen won't work, they use a different value but any third gen will work.
Old Mar 15, 2011 | 05:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
4th gen pickups just plain don't fit in 3rd gen tanks. The V6 4th gen sending units use the same resistance values as 3rd gens, though. You'd just have to swap over the entire tank.
EFI sending units have a different connector and shorter leads than carb car sending units.
Non-in-tank-electric-pump pickups were used from '82-'86, or 5 years. They made more 3rd gens during those years than they did the last 5 (although admittedly even some of the '82-'86 had the in-tank pump). Have you posted on the TGO "parts wanted", or searched the "parts for sale" classifieds? You might find one.
Old Mar 17, 2011 | 07:18 PM
383 Power's Avatar
I think i hit a Homerun. Found a 1985 Camaro today that still had the Gas Tank. I was expecting to see a bunch of wires coming off the sender, but to my delight, there were only 2. I guess this means that the car was carbed, right? anyhow, i looked at the tank and it SEEMED to be sound. Here in Shreveport, all the junkyards puncture the tanks, but this one seemed unmolested. How could it be? I dropped the tank (A really nice looking tank) and could not find a hole ANYWHERE. Neither could the owner of the Junkyard. I picked up the whole unit for $28. What do you guys think?
Attached Thumbnails Fuel Level Sender Interchange-img_20110317_184620.jpg   Fuel Level Sender Interchange-img_20110317_184626.jpg
Old Mar 17, 2011 | 07:44 PM
travis401's Avatar
Car: 91 Camaro RS
SCORE!!
Old Mar 17, 2011 | 11:36 PM
five7kid's Avatar
Old Mar 18, 2011 | 02:47 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Awsome man! My aftermarket tank that is CRAP spectra ran me $250.00. Wish I had a junk yard around when I needed one.
jklein337
Sep 19, 2018 06:23 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
