1 spade vs 2 spade?
Subscribe
Mar 24, 2011 | 06:48 PM
I'm buying an electric choke conversion kit for my Camaro off of Ebay. The 1 spade conversion kits are about $30 cheaper than the 2 spade one. Whats the reason for this? Are the 2 spade caps better for some reason?
Reply 0
Mar 24, 2011 | 06:52 PM
Re: 1 spade vs 2 spade?
If by spades you mean terminals, I know the 2 spade is a 12v+ wire and a ground. Not sure how in the world a single connector would work, unless the cap is metal, and they assume you can get a ground through the carb. I've never seen a single terminal choke housing.
Is this a stock carb? Thought they all already had electric chokes?
Reply 0
Mar 24, 2011 | 06:54 PM
I'm pretty sure that's the way stock carbs on these cars came, my Trans Am is CCC and it has a 1 terminal connection.
Reply 0
Mar 24, 2011 | 07:07 PM
I have Edelbrock, it has 2 wires for the choke, since the choke housing is plastic it has to have a ground. Most Holley's I've seen are the same. So factory Qjet must get a ground elsewhere rather than on the choke cover.
Reply 0
Mar 24, 2011 | 07:27 PM
Well my Edelbrock 1406 has 2 as well...I'm kind of stumped as to how this would work but I bought one lol.
Reply 0
Mar 25, 2011 | 08:00 AM
hmmmm......
Reply 0
Mar 25, 2011 | 11:38 AM
The factory choke grounds through the choke housing. The plastic cover insulates the choke coil terminal from shorting to ground and bypassing the coil.
Reply 0
Subscribe
