82 powr door lock wires ?
Old Jan 12, 2006 | 11:27 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok under the console of the 82 Z-28 are four wiring plugs that all tie together in some way or another:
a three spade relay plug with relay 329820 and wires yellow black and brown
then theres a straight across three spade connector with nothing plugged into it(i assume is for a power door lock switch) with wires orange black and gray
then theres a single orange wire with a female spade end and then theres the same brown wire (from the relay plug) with a female spade end, about 6" long wire
all packed under console area in same place
if only i had a freakin digicam
does anyone know anything ?
im trying to confirm if this is a power lock car or not,
theres no engine in it and no real way to connect a battery to the car and find out really
both accessory relay slots in the fuse panel have a metal relay in them
does not have power windows or a/c
power lock relay would only be three spade and small square case one right ?
thanks
Old Jan 12, 2006 | 09:03 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
The power door lock relay for an 82' Camaro will be behind the drivers kick panel, if the car indeed has power locks. Can't miss it.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
