Thunder AVS TV Cable linkage?
I just went to go install my new Edelbrock Thunder AVS (1806) carb on my 1986 T/A LG4 engine when I saw that the carb only has allowance for my cruise control and accelerator cable linkages. Since my car is an automatic running the 700r4, I have a TV cable that I need to hook up still. How can I do this?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Thunder AVS TV Cable linkage?
This is needed - connects TV cable AND ... very importantly corrects the geometry of the cable so correct pressures are incurred:
http://www.summitracing.com/parts/SUM-700203/
Car: 1992 RS
Engine: Carbed 350
Yes. This adds a place for the TV cable, and is necessary to keep geometry on the cable connection correct. Failure to use could burn up the tranny quick. Improper TV cable setups have been known to kill tranny in a little as 3 blocks of driving.
TMZIrocZ350
10-07-2015 12:09 PM
