Converted to e85 now the carb is weird ...
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Like the title said. If I hold throttle steady at say 2000rpm and take my foot off it idles for a second or two then reads dead lean and dies could someone point me in the right direction.
The Carb,
Holley
1000cfm with annular boosters
The Carb,
Holley
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Converted to e85 now the carb is weird ...
What kind of fuel setup are you running? And just to clarify - you had your carburetor modified for E85, correct (not assuming anything, as I've actually seen this attempted before without conversion so I figured I'd ask)?
Transmission: 4L80E/4L80E
If you didn't completely recalibrate the carb for E85, you didn't "convert" to E85.
Yeah I forgot that I got the quick fuel metering blocks to run e85.
As for the fuel system -10 to magnafuel 300 pump -8 to reg -6 to each fuel bowl. 6psi
I'm sure its simple.
I talked to one of the local fast guys about my problem and I was right it was a simple issue. Thx five7 for that Pearl of wisdom
theshackle
Mar 5, 2017 06:37 PM
C409
Sep 1, 2015 03:42 PM
85, car, carb, carberatuer, carburated, carburetor, carburetors, code, convert, e85, ethanol, flex, fuel, holley, thirdgen, trans
