thought it was the TPI
Old Apr 9, 2011 | 10:38 PM
Postman84's Avatar
Worked all day trying to fix a carb problem. Car would run then die. and never seem to be very good. Got into the 84 camaro, 2.8 V6. First found the carb was very loose. Then found the starter was very loose. Replaced the positive cable, and still having the same problems. Finally ask my son if he changed the gas filter. "No" So we changed that and sure enough it ran a hell of alot better. Took it out for a test drive and it died, but not from the carb. The new positive wire shorted on the exhaust. So tomorrow get another cable. My question is how the hell do you tighten up the nuts that hold the carb on the manifold? We used everything we had to get the nuts off and put them back on. Why would they make a Rochester carb that a 1/2' wrench won't fit. Someone teach me the secret to that one.
Old Apr 10, 2011 | 01:25 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: thought it was the TPI
a socket's probably a better option than wrench for the main 4 bolts. Never tried a wrench.
Old Apr 10, 2011 | 02:35 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
they probably are metric as well
Old Apr 10, 2011 | 05:19 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
prolly^
Old Apr 11, 2011 | 09:26 AM
Postman84's Avatar
I think you are correct on it being a TPI. But for what others have said, I not get a socket in there or a wrench. It is a rochester Varijet is it. Anyone ever taken one off. I would like your input. Also is there a break down of this TPI on the web. I would like to know which is the idle screw. Thanks.
Old Apr 11, 2011 | 09:33 AM
Postman84's Avatar
More questions
Your correct on it being a TPI. It is a Rochester Varijet (?). I am still looking for someone who has removed one. A socket and wrench no go on most of them. Used a needle nosed plyers to tighted them. The bolts are surround by the TPI, not an easy thing to get at.
Also is there a diagram of this TPI on the web, so I can tell which screw is the idle, also the adjustment on other fuel screws and there location.
thanks.
Old Apr 11, 2011 | 01:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why do you keep referring to "TPI"? If it is a carb, it is not "Tuned Port Injection".
Old Apr 11, 2011 | 02:45 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Carb & TPI are like NIGHT & DAY...No wonder he has problems.
Old Apr 11, 2011 | 04:16 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I just put a Rochester Varijet carb on my bird. The nuts are 13 mm. As for how to tighten them I was able to do the back two and front passenger side with a wrench. The front driver side I had to use needlenose but it was taken off with a wrench originally. I am thinking of grinding down a wrench just enough to work. I was hoping to be done but problems with the accelerator pump and idle circuits. Coming off for a full meticulous rebuild. This explains why I want to modify a wrench to work.
Old Apr 11, 2011 | 10:48 PM
Postman84's Avatar
Looks like a carb but everything I read keep talking about TPI. So I was a not sure.
Old Apr 11, 2011 | 10:50 PM
Postman84's Avatar
Thanks 91phoenix for the input.
Old Apr 15, 2011 | 10:51 PM
LUCKY 1's Avatar
Hi everyone tpi is a beatiful cosmetic look Ihave a problem though. I had my brakes redone from sitting for 20 years very good greased now my camaro 5,7tpi vet motor , at idle 1,000 rpms put foot on nibble on gas slowly doing 10 mph it stays at 1,000 and even seems to pick up speed I saw a screw on THE BACKSIDE OF THE PULL BACK CABLE can i put it in a lil too let idle go down then take off battery to reset factorty settings? at 45 mph she won't seem to slow at all , even when Ithrough in neutral. at this rate i am going to need brakes for real reason while just rusted together from sitting from new 20 years! LUCKY 1
Old Apr 16, 2011 | 08:34 AM
jtsk's Avatar
Lucky 1, if I am understanding what you are saying, that screw you are talking about most likely wont lower your idle. The computer controls the idle through the IAC valve. Most likely, that is the source of your idle issues.
Old Apr 16, 2011 | 11:32 AM
LUCKY 1's Avatar
Hello Jtsk
wow purple camaro 92 z28 LOVE THEM! yes going to ask maybe you know? mecanic put a k and n filter on mine.. Maybe too much air entering? thus more air more fuel? This moring Itook off battery positive
have heard people trying to reset to factory settings? and one more iac valve can I find it? any help there Thanks LUCKY 1
Old Apr 16, 2011 | 01:31 PM
jtsk's Avatar
Lucky 1, check this out, It should help.
https://www.thirdgen.org/forums/tech...-location.html
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
