Erratic Idle question.
Old May 6, 2011 | 09:37 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
750 DP Mech 2nd's. On start and warm up car idles at 750 RPM. Primaries are alittle rich. When getting the car "hot" around 185-195 and driving, the idle increases. Can't find any vacuum leaks. Would the primaries running rich cause it to "idle up"? Would fuel lines possibly getting heated by headers cause this?
Old May 12, 2011 | 07:03 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: Erratic Idle question.
Did you spray carb cleaner around the whole carb when it is running?
Old May 13, 2011 | 08:23 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Sounds like you need to adjust your idle mixture screws, try turning them out 1/8 of a turn and reset your idle if effected. Run it around and see if it helps. It is starting to run lean when the idle increases like your talking about so that means more air is getting in somewhere.
Old May 13, 2011 | 07:20 PM
remltr's Avatar
Carb cleaner, ether, brake cleaner, all but pouring fuel around the carb and vac lines, no leaks. Adjusted IMS using a vac gauge..9.5-10" at idle. Will try again. Noticed that if I pump the brakes idle increases. Ran car, shut off pull hose from booster and I get the rush of air. I read that pumping brakes effectively causes a "vacuum leak" increasing the idle. Possible problem with the booster? Check valve seems to be ok.
Old May 26, 2011 | 08:22 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
You will always get the rush of air. Pressing your brake pedal down will actually lower your rpm but when you release the brake the idle will pick back up. Does this happen when sitting or driving?
IROCtometal
Sep 20, 2015 11:08 PM
corey8084
Sep 17, 2015 02:56 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
Ian Irvine
Sep 4, 2015 08:08 AM
