Carb setup questions
Old May 18, 2011 | 06:23 PM
lionsfb57's Avatar
Car: 87 iroc z
hey guys a few questions, in a 93 trans am, the computer is setup for a stock 5.7 lt1 engine which is fuel injected(not with the car). now the car doesnt have the engine with it so im putting a carbed 383 in it. My question is if i remove the wiring and stuff on the passanger side (like ive bin told) and just use the carb, how would it be able to be inspected in pa? (emissions laws and whatnot). i know they plug into the thing under the drivers side to get readings but if i remove all that wiring on the pass side would it affect being able to be inspected?
Old May 18, 2011 | 07:23 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: Carb setup questions
I would recommend calling a shop that does inspections or even a dealership and asking them the same question. In NY only 96 and newer cars go on the computer because its OBD2 connection only.
Old May 18, 2011 | 09:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You do realize that to carb a motor in a 4th gen car you have to do some cowl and firewall cutting right? The 4th gen cars the motor sits too far under the cowl, and you can't fit a carbed motor into a 4th gen body with some modding of the firewall and the cowl in order for the carb to fit.
Old May 19, 2011 | 06:33 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
lt1s are dirt cheap. Go buy one and put it in.
Old May 19, 2011 | 09:37 AM
lionsfb57's Avatar
Car: 87 iroc z
well ****. that kinda sucks. well i have an edelbrock intake manifold for fuel injection(this one i think http://www.summitracing.com/parts/EDL-7109/?rtype=10) and a throttle body. what else would i need to convert this engine over to fuel injection? the car's computer is still in there along with all the wiring just dont know where everything plugs into and whatnot
Old May 19, 2011 | 11:09 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
In PA (at least around here), it is a visual inspection only. They will be looking for all of the original smog equipment...when they see a carb, you will fail. Unless, of course, you can prove that the carb conversion is smog legal (CARB exempt parts work well). In the end, I don't see this thing passing...unless you have a good friend that is an inspector.
Get an LT1 manifold, computer and wiring harness if needed. The LT1 manifolds work well and you can make good power with them.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
