Edelbrock 600 cfm choke problem
Old May 18, 2011 | 11:53 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
During the cooler weather my 600 cfm Performer's choke will stick on me. I have to rev it up around 3000 rpm to get it to kick out but as soon as I start driving it again the choke sticks again!!!
Now that we are into spring and warmers temps, the problem goes away. But as soon as the outside temps get down around 40F the choke will start playing its stupid games on me again. I've had this carb for about 6 years now and the problem just won't go away. Summer driving is perfect but when fall and winter come along, the choke sticks again.
Does anyone know the answer to this problem? Some pictures of how to fix it would be very much welcome, as I will need to get the neighbourhood kid mechanic to do the repair.
Thanks all!
PS It is the standard Edelbrock electric choke.
Old May 19, 2011 | 01:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Edelbrock 600 cfm choke problem
How long is it taking to open?
Old May 19, 2011 | 01:53 AM
Engine: 305-4v
Hi Chris,
When it is 40F or cooler the choke simply goes back on, whether I kick it down 20 times or not. Just plain annoying!
How are you doing? Long, long time no see!!!
Old May 20, 2011 | 12:48 PM
Engine: 305-4v
Also, the choke does not come back on at as fast an rpm as when it first starts. It will start at 2000 rpm and after a minute I kick it down and it sits at 1500 rpm. Finally after it has warmed up to its normal driving temp it will idle around 1000 to 1300 rpm. But that is a very large annoyance to me, having to step on the brakes so hard to come to a stop.
Old May 20, 2011 | 12:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is the choke plate closing again when the idle speed comes back up? How have you got the tension set up?
Old May 20, 2011 | 08:25 PM
Engine: 305-4v
This I do not know. My back is only worse since you lived here in Calgary, so leaning over the engine is a very miserable experience. Moreover, unless the outside temp goes back down to those cold values I have no way of telling!
What I wouldn't give for an Edelbrock expert like you Chris to be living here in Calgary!
Does anyone know of a really good Edelbrock carb man here in Calgary?
beastin91rs
Oct 9, 2015 07:38 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Ducati900ss
Sep 2, 2015 09:05 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 17, 2015 02:00 PM
