Fast idle issue
Old Jun 2, 2011 | 09:39 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Fast idle issue
have an 86 with a lg4 and fast idle solenoid always has power.....was wondering if anyone has had this issue
Old Jun 4, 2011 | 02:48 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: Fast idle issue
The solenoid you are describing is for you air conditioning, or when you have your defroster on. It is there so your engine doesn't stall when your air conditioning compressor is on. My solenoid wanted to stay in high idle mode even when the compressor was off e.g. when on heat or vent. I simply disconnected the wire to it. I do not use air anyway.
Old Jun 4, 2011 | 05:16 PM
anthony714's Avatar
Re: Fast idle issue
lmk.i have the same issue and for the life of me cant figure out why,and unfortunately i had to unhook it for now..
Old Jun 4, 2011 | 06:11 PM
Re: Fast idle issue
I am ok with unhooking my solenoid, but I don't know if it is the solenoid its self, or is it getting constant power.
Old Jun 4, 2011 | 09:36 PM
anthony714's Avatar
Re: Fast idle issue
dont unhookit,fix it. i got a thumper of a motor and even with my motor it doesnt like the ac on. you an feel it at idle. needs the kicker. mine has constant power,not the solenoid. use a simple test light to check yours or make one. a12v light bulb and 2 pieces of wire. mine is dead until i hit the ac,it powers the solenoid like it should but after you turn the ac off the power remains..thats the bugger for me..any help anyone?
Old Jun 5, 2011 | 07:17 AM
Re: Fast idle issue
I would also like to know what needs fixing. Until then, is stays unplugged.
Old Jun 5, 2011 | 05:57 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Re: Fast idle issue
I did'nt have a problem until I removed the electronic Q jet & distributor....not sure if thats why....I do not believe the computer effects the fast idle solenoid. It is a must with a car with A/C. Any help with this would be appreciated.
Frank
Old Jun 6, 2011 | 06:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a circuit for the computer to activate the fast idle solenoid.
Old Jun 6, 2011 | 07:16 PM
Re: Fast idle issue
Can you give more details?
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
