millionth time this question has been asked
Old Jul 7, 2011 | 06:56 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Ok. For the millionth time. I picked up a car last year that was tpi, now carbed. 85 z28. I have now taken out ecm and wiring harness is sitting in engine bay. I now want to get it out. The previos owner had left a bunch of cut wires inside the loom. I pulled those first. But I still have a bunch of wires that are hooked up to stuff that I don't know what they are and they are part of ecm harness. I will describe some and hopefully somebody can tell me what they are. I can't attach pics because phone won't let me, but if someone can let me text or email them some that would be sweet. My first one: a relay box of some tpye, has big fat orange that has been spliced into batery hot, twice. Then has a green and white wire and a brown and white.
Old Jul 7, 2011 | 07:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: millionth time this question has been asked
If it comes out of the ECM harness on the pass side loom, it can come out.
If it's not a factory wire (like that rigged-to-battery mess you describe), then your kinda on your own - grab a VOM and trace it out.
Old Jul 7, 2011 | 07:25 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
It was a factory wire because it comes out ecm harness, but what the relay. Is for I have no clue. So basicalyy though if it is one of the wires on the ecm harness I can trace it however far it goes and take it out?? A lot of them go towars the dizzy are and I haven't traced any further fron there. I know some are coming from that area which has to do with heat and ac , but I have eleminated ac so the rest should be easy to trace
Old Jul 7, 2011 | 08:23 PM
Car: 1992 RS
Engine: Carbed 350
Relay could be fuel pump relay, or a fan relay, or a MAF relay (if your car had MAF).
There are a few wires that generally run from pass side to driver side in the rear (over the tranny) loom, these would be fuel pum prelay wires maybe, and possibly a few others to other sensors on the driver side.
Old Jul 8, 2011 | 09:47 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Maybe your fan relay, some of this stuff looped thru the ecm. I would trace it out good before cutting anything else. No matter which side it comes from.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
