Carb question?
Old Jul 20, 2011 | 01:22 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Carb question?
Will my car run ok with cc q jet and non cc distributer? Computer has been disconnected
Old Jul 20, 2011 | 01:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carb question?
No
Old Jul 20, 2011 | 01:40 PM
DoubleV's Avatar
Re: Carb question?
This has been covered countless times; yes you can run a CCC carb with the computer disabled/removed but it will always run way too rich and is therefore the wrong choice.
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Re: Carb question?
Ive already done it and it seems ok
Old Jul 20, 2011 | 01:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Carb question?
It's not. Wait until you check your mileage.
Old Jul 20, 2011 | 08:07 PM
Re: Carb question?
it seems ok
Alot of half-a$$ed stuff in the world does, until you get the opportunity to see how much BETTER it can be when done RIGHT.
Old Jul 20, 2011 | 10:17 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Re: Carb question?
Car is mainly used for strip use although its driven to track...computer was eliminated for consistency.I had a non cc q jet but cc carb seemed to accelerate better.I only want try going back to cc carb.
Old Jul 20, 2011 | 10:25 PM
BillyTheGoat's Avatar
Car: 1989 Trans am
Re: Carb question?
Don't do it. The previous owner had one on my car and it ran horrible. It would randomly stall and would barely accelerate. I bought a holley 600 cfm carb and its way better
Old Jul 21, 2011 | 03:29 AM
DoubleV's Avatar
Re: Carb question?
So since your CCC carb was f*cked up and ran horrible, that means everybody elses will run horrible too? That's not a real convincing argument...
FJA1791, if you want to go the CCC carb route, do it right and run the whole CCC system. If you don't want to run it on the computer, do it right and get a non CCC carb. Any other way is wrong.
Old Jul 21, 2011 | 08:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
For strip use, you may get away with it.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
