BROCK 600 help
Old Jul 22, 2011 | 03:08 PM
Lumarus's Avatar
Car: 1982 Z28 T-Top Camaro
Engine: Vortec 355
Transmission: T-5 5Speed Manual
Axle/Gears: Stock Limited Slip
BROCK 600 help
my car is hard to start, and when it does start it idles rough between 300rpm n 500rpm and slowly gains rpm over 30 seconds to 800 rpm thne is fine. if i punch the throttle to the floor the car trys to die, or sumtimes falls to bout 300rpm and then rapidly picks up to 4k rpms or higher. if i slowly put my foot into the throttle it piks up fine. is this a mixture screw problem with my carb or something else?
i have no vacuum leaks that i can tell, my vacuum advance is set up on driver side port for FULL vacuum. i have a cheap off the shelf inline fuel pump that puts out about 7lbs of pressure, i have a regulator set on 4 1/2 lbs of pressure. i was told not to set it over 5lbs of pressure. anyone have any ideas?
Old Jul 23, 2011 | 05:18 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: BROCK 600 help
Remove it and clean it, that's an old piece, I'd run 5lbs.psi myself.....
Old Jul 23, 2011 | 12:33 PM
Lumarus's Avatar
Engine: Vortec 355
Re: BROCK 600 help
its bran new lol
Old Jul 23, 2011 | 12:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: BROCK 600 help
You followed all the instructions in the manual for setting the float height, installing and tuning?
Old Jul 23, 2011 | 01:36 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: BROCK 600 help
these carbs are virtually fool proof HOWEVER they are not emissions compliant!! if the laws in your area are such that you can run this carb,i would begin with a careful rebuild,THEN i would run a holley blue FP regulated to 7 lbs fuel pressure,check the VOLUME of fuel too it should produce 1 pint in thirty seconds for satisfactory results
Old Jul 23, 2011 | 04:04 PM
J91's Avatar
J91
Re: BROCK 600 help
Originally Posted by Lumarus
its bran new lol
My mistake, thought you had an original carb on there... Brock/ Edelbrock, duh, what can I say, I run a Holley....
Old Jul 23, 2011 | 04:36 PM
Lumarus's Avatar
Engine: Vortec 355
Re: BROCK 600 help
ya thankin i shulda ran holley too. but already got this brock so ima stick wit it. its new but the mixture screws got messed with, so did the idler screw, and the mechanic still didnt fix my hesitation, said he didnt know, couldnt figure it out... no charge have a nice day. lol so im tryin to adjust myself. i needa buy a timing lite i know and just go over everything myself again. just getting fed up with this car.... blah. oh well keep pushin thro!
Old Jul 23, 2011 | 05:30 PM
J91's Avatar
J91
Re: BROCK 600 help
They are easy to tune, do you have the manual / instructions, if not you can download it. Like it was said above they are almost foolproof. Unfortunately there are alot of mechanics out there nowadays who don't know chit about carbs....
bbsr72
Apr 2, 2016 09:12 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
aharvel50
Sep 21, 2015 07:31 PM
makaveli09
Sep 15, 2015 10:43 AM
