think line stopped up in tank
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: think line stopped up in tank
I hate the idea of cutting the car - but I'd think the trap door would be easier initially, but need to be tastefully done to reseal the "hole" left behind.
I'd personally drop the tank - requires no fabbing.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
make a door makew a door make a door, dunno how many times ive been back in there and if i had to drop rear end every time.
like last Sat night, if I had a flashlight, I could of fixed my fuel pump and drove home instead of towing it and fin up my airdam.
but sitll after towing home, I had it fixed in hrs next day as I had easy access.
Transmission: 4L80E/4L80E
Why do you think the line is stopped up in the tank?
Think about what would stop up the line. I can think of two things: 1) Crud in the tank that plugs up the pick-up sock; and 2) a rusted or crushed line. If 1), then you'll want to drop the tank to clean it out (if possible - you may have to replace it). If 2), the line isn't likely to rust inside the tank without the rest of the tank rusting, and for sure isn't likely to get crushed.
I think more information is required before usable advice can be offered.
Also, think about what you are doing and what you're really getting with the trap door. The factory didn't put any line connections there, so you're going to have to cut them as well, then splice them back together when you put it back together (that goes for the electrical wires as well). While cutting out the door, you run the risk of cutting something you don't want to cut, and if things really go sour on you, starting a fire.
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
