afpr setup...
Old Aug 19, 2011 | 11:39 PM
ChevyRS-305's Avatar
afpr setup...
Just wanted to see how you guys set your fuel lines and afpr up. Where did you mount and rout everything and what size and length hoses did you use roughly. Just trying to map some things out. Pictures would be nice. Thanks
Old Sep 13, 2011 | 02:47 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: afpr setup...
I don't have a picture handy but I came up of the pump and mounted the afpr and gauge to a fabbed bracket I mounted to a strut tower bolt.
Fuel line is routed to the carb from there following the STB.
Afpr is a Holley unit.
Old Sep 13, 2011 | 02:55 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: afpr setup...
There's a couple threads on here with quite a few pictures. Search for them and that should help you out.
Old Sep 15, 2011 | 11:09 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: afpr setup...
easiest place IMO, is right above the stock hardlines on the driver side strut tower. theres a thread on here about someone overhauling their engine bay and its got adapter fiting sizes in it to hook the stock hardline to AN line to run braided stainless hose. two short hoses up to the reg, one longer hose out and over to the intake.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
