91 suburban 5.7 swaping to carb
It going into my 88 camaro and im having trouble making the intake line up they told me i have to eather drill the holes in the intake but it still dont seem like its going to line up. iv been trying to find a intake for vortec heads but everything i find dosnt say it will work on vortec heads. can somone help me find one iv been looking. but cant seem to find one
Re: 91 suburban 5.7 swaping to carb
well im realy putting it in a 78 Monte Carlo but its a center bolt valve cover 350 like my 88 Camaro. and i know the 2 center bolts on eather side on the manifold are drilled different then the older 350's. just wanted a liittle feedback before i mess up a manifold trying to make the holes bigger there off by less then a centimeter
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
There are basically 3 types of heads. Old pre center bolt heads you know the type standard. Then there are the TPI swirlport heads and then real vortec heads. I think true vortec heads only came in 96 and later but sometimes the pre vortec TBI heads are called vortec. Both have center bolt covers. The TBI heads and manifold are very close and with some drilling you can make a regular manifold fit. Or you can just buy the correct one.
Either way the Edelbrock or equiv 7116 manifold will work for true vortec heads.
For the 91 surburban TBI heads here is a list from summit racing
http://www.summitracing.com/search/Y...d/?Ns=Rank|Asc
The image blow has a standard SBC square port gasket over a true vortec intake port the heads are also drilled for both types of manifolds. This may help you.
Transmission: 4L80E/4L80E
You need an '87-up intake, NOT Vortec. As stated, the Vortec heads started in 1996.
Take your pick:
http://www.summitracing.com/search/D...l/?Ns=Rank|Asc
Or, you can elongate the center two mount bolts on each side so they line up with the bolt holes in the heads. If you're only a centimeter off, then you may want to just go ahead and do that with the intake you have.
Take your pick:
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
