found strange wire, where does it go?
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: found strange wire, where does it go?
Looks like the idle stop solenoid wire. Doesn't look like your carb has it.
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
no idea man, kinda why i posted, why would i have the wire without it though? this cars original with 30,xxx miles and the engine, while a little dirty and has a few probs is all original too
Car: 1987 Camaro LT
This piece.
Transmission: 5spd
nope, doesn't have one, car runs good without it i think i had the idle set way too high today though, kicked it back down and she was all back to normal, last time i let my dad tell me my idle needs adjusted
If your car originally came with A/C you should have that solenoid mounted on the front/driver's side of the carb. It opens the throttle slightly to raise the idle speed when the A/C is on. Just 2 screws to remove it, so it's entirely possible it got removed by a previous owner or the carb was replaced with a rebuilt unit at some point in the car's life (rebuild carbs don't come with that solenoid- you're supposed to carry it over from the old carb before you install it).
Transmission: 5spd
could be, idk it doesn't seem to be hurting anything by not being hooked up, my ac controls are always on and there constantly hissing, but thats cuz i havent fixed the vaccum lines behind it yet
eightsixseven
Dec 16, 2024 01:50 PM
red90IROCls1
Aug 25, 2015 06:56 AM
