Can't get this thing to idle
Old Nov 11, 2011 | 09:56 AM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
I'm using a computer quadrajet and I can't get the car to idle by itself. For the fast idle screw do you turn it in clockwise to raise the idle? And I can't get the car started unless I pump the gas pedal. Isn't that ruining the fast idle part, when you hit the throttle?
car will not idle cold or warmed up.
I have no vacuum leaks.
Old Nov 11, 2011 | 10:19 AM
camaro2's Avatar
Car: 1986 Camaro
Engine: 355
Transmission: Turbo 400
Axle/Gears: Narrowed Ford 9"
Re: Can't get this thing to idle
I have had issue's with quadrajet carbs idling. The issue I have had with them is a vacuum leak on the throttle shaft, you might check that out.
Old Nov 12, 2011 | 03:23 AM
DoubleV's Avatar
Yes.
That's the way it's supposed to work assuming you're refering to having to give it just a few pumps and we're talking about a cold engine.
Hitting the throttle on a cold engine is a good thing. It puts a little gas into the carb and just as if not more important it 'sets the choke' which means the choke will close and the fast idle will be on it's highest step ( there are multiple steps ).
Once the car starts, it's usually ideling pretty high if everythings set to near factory specs. You can then immediately hit the throttle and it should fall down to the next lower fast idle step which should put your idle at an RPM which will allow it to idle good even when in gear. Eventually the choke will heat up enough to where it won't be on any of the fast idle steps and instead be on your normal ( or 'curb' ) idle which is controled by the idle screw on the drivers side.
There could be many causes for this. Was this something that happened suddenly or has it always been like this?
Are you sure? What did you do to verify no leaks?
Old Nov 24, 2011 | 12:00 PM
0pyders's Avatar
Ah I fixed it. I forgot to check the vacuum hose behind the carburetor that goes to the vacuum sensor(?) and it was NOT plugged in. Got the idle working good now. Thanks for your time.
bamaboy0323
Sep 3, 2015 06:07 AM
Logan Bryant
Aug 27, 2015 11:52 AM
86IROC112
Aug 21, 2015 07:20 PM
Bob88GTA
Aug 18, 2015 03:31 PM
