Carb Problem??? OR NOT
Old Dec 23, 2011 | 05:35 PM
redzee85's Avatar
Car: 1985 z28
Engine: 5.0 LG4
Transmission: Built 700R4
Axle/Gears: 3.08
I have a 85 z28 with the LG4 in it. I'm only 18 and I just got the car last September and it is my first experience with a carbed motor. The person before me half-a**ed everything when they tried to fix it. He said they rebuilt the motor and couldnt get it running right. That they went through 6 different carbs but when I bought it, it was the timing that was way off and i had the carburetor tuned, which is a edelbrock.
But the point when I am in low throttle sometimes maybe mid it feels like the car is not getting any gas and is cutting back...I highly doubt its the tranny, i just had it fully rebuilt.
Is it a bad carb? or something else? I have also read somewhere that it has something to do with it being a different carb then than factory quadrajet with the distributor....
Old Dec 23, 2011 | 05:42 PM
JTS's Avatar
JTS
Car: 83 Z28, 85 Burb
Engine: 305 Carbureted
Transmission: 5 Speed
Re: Carb Problem??? OR NOT
If the distributor is not computer controlled and the carb is, you will have problems. The PO of my car swapped out the dist with and HEI and then he ran in to carburetor issues. I have a non-computer edelbrock q-jet I'm going to rebuild for my car...hope to have that done in a couple days.
Old Dec 23, 2011 | 05:46 PM
redzee85's Avatar
Car: 1985 z28
Engine: 5.0 LG4
Axle/Gears: 3.08
How would I be able to tell if either one of them is computer controlled?
Old Dec 23, 2011 | 06:56 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the carb will have electrical connections on it(more than one). if it doesnt its not computer controlled. the dizzy will be wither a small cap with 9 plug wires on it (computer controlled) or a large cap with the coil mounted on top and only 8 plug wires (non computer controlled)
Old Dec 23, 2011 | 07:04 PM
redzee85's Avatar
Car: 1985 z28
Engine: 5.0 LG4
Axle/Gears: 3.08
Im planning on building a motor for the car soon... Would it be best to keep everything computer controlled or non-computer controlled?
Old Dec 23, 2011 | 11:05 PM
travis401's Avatar
Car: 91 Camaro RS
depends on which you you wanna tune it. to be street legal youll need everything computer controlled. you can be "street legal" on non computer controlled equipment since i doubt you have to pass strict emissions in NC
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
