Carb float question
Old Dec 25, 2011 | 07:01 PM
Bigdeerock's Avatar
Carb float question
First off Happy Holidays,
Now off to work. I am restoring an 82 Camaro SC 4 bbl. I have had an issue of the car smelling like fuel out the tailpipes, to the point where i would have to leave the garage. It has an Edelbrock 1406 installed by PO. I dont know anything about carbs, Im learning as I go. Anyway I checked the float adjustments and compared as per the instructions, I noticed the following. With the airhorn cover upside down the floats were at 7-8/16 of an inch (normal) however with the AH rightside up the floats dropped to 1.25 inches (directions say it should be 15/16 to 1 inch), a .25 inch difference!!! could this be the culprit for my fuel smell??? no vac leaks noted.
Thanks in advance and I hope everyones holiday was blessed and safe.
Old Dec 26, 2011 | 02:14 AM
Damon's Avatar
Re: Carb float question
Float adjustments are well known for being bad out of the box on Edlebrock carbs. I doubt that's the main cause of your problem, but it should be addressed while you have it apart anyway.
Old Dec 26, 2011 | 10:27 AM
Bigdeerock's Avatar
Thx Damon. I havent checked fuel pressure yet. PO said he changed the fuel pump before I bought it. stupid fuel test gauge is like 40 bucks so itll have to wait. while I have it off Ill check the jets and rods to see if he calibrated it differently, if there is anything u think that could cause my condidtion let me know.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
