Wires coming from distributor
Old Dec 26, 2011 | 09:26 PM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
Transmission: Th700R4
Axle/Gears: 3.73 Posi
Ok im working on my carb swap from TPi and i just put my new vaccum advance distributor in there are 3 wires coming from it as pictured below. The question i have is I only have 2 wires coming from my stock harness how do i make it work?
Old Dec 27, 2011 | 10:27 AM
Badasscamaro346's Avatar
Car: 87 camaro
Engine: v8 carb'ed
Transmission: 5 speed
Re: Wires coming from distributor
the 3 wire connector connects to the distributor cap. (right behind where the 2 wires from your main harness connect). If you look at the first pic, your thumb is pointing at the spot where the 3 wires connect to the cap
Old Dec 27, 2011 | 03:31 PM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
alright i see, so what do i do with my 2 stock wires?
Old Dec 28, 2011 | 05:36 AM
one92rs's Avatar
Car: SOLD!!!!!
the pink wire is going to be your power wire for the distributor. the white one is going to be your tach wire.
Old Dec 28, 2011 | 09:41 PM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
so splice the pink wire to the red and the tach wire to the yellow?
Old Dec 28, 2011 | 09:48 PM
Damon's Avatar
There are TWO sets of connectors aready build into the distributor cap. Closest to the body of the distributor is a row of 3 terminals that your 3 wire plug with pop right onto. Further out on that "square" protruding from the side of the cap is a set of 2 ADDITIONAL connectors- that's where the pink and wire wires go. Pink to "+12V" terminal, white to "TACH" terminal.
That green wire in the picture is NOT the tach signal wire. The tach wire in a stock wiring harness is white (often faded a little yellowish over time, but definitely not green). The Tach signal wire should also have the same style of connector on the end that your pink/power wire has.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
stalkier
Aug 7, 2015 04:49 AM
