82 Camaro z28 bogs, jerks, and sputters on acceleration
Old Jan 6, 2012 | 03:05 AM
Yng82Z28's Avatar
Well i have a 1982 Z28 Camaro 305 sb 4bbl HO...About two weeks ago i started experiencing really bad surges, jerks in the car, engine bogging, and sputtering. I had no clue as to what could cause this problem...It would only happen on acceleration...the cars idle is very high.when driving i would hit the gas and the car would feel horrible from constant jerking and sputtering....WHAT COULD THIS BE??? Ive done some research and narrowed it down to the air and fuel system; Bad fuel pump or fuel pump relay, I have been running out of gas alot lately becuase the gas gauge and rpm gauge works when they want to. I also noticed in the fuse box the fuse for the fuel pump is missing as well as some other fuses... Wierd thing is, theres no way to connect a fuse in some spots becuase of missing fuse connectors
PLEASE I NEED HELP. WHAT COULD THIS BE AND WHAT CAN I DO TO FIX THIS??? Heres a video of it running http://youtu.be/CYMK1HkB72M
Old Jan 6, 2012 | 05:09 AM
robvano's Avatar
Car: 72 Chevelle
Engine: 468
Transmission: Muncie
Axle/Gears: 355
Re: 82 Camaro z28 bogs, jerks, and sputters on acceleration
I believe your car maybe carbureted and that’s why you don’t see fuel pump fuses or relays. The high idle and poor running condition may be caused by vacuum leaks at the intake. I’d check for bad or disconnected hoses, carb gasket and any intake fittings.
Old Jan 6, 2012 | 01:21 PM
nitrq's Avatar
Car: 1988 camaro
Engine: 355 blueprint engine
Transmission: 700 corvette servo
Axle/Gears: stock 4.11
im having the same issue on my 88 camaro with a 355 and eldebrock carb setup
Old Jan 6, 2012 | 02:55 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Don't assume it's the carb. Make sure your ignition is up to snuff. How long since you replaced the cap, rotor, plugs and wires?
Old Jan 7, 2012 | 12:10 AM
Yng82Z28's Avatar
For some reason I can't remember, I poured gas over the Carb and 15 minutes later it ran almost perfect..no bs I guess the gas did something....I got a gallon from the gas station, put it in..at first it would not start...For some reason I popped the hood, took the air cleaner and poured a little bit of gas over the carb and 15 minutes later it drove with no surges bogs or sputters....so damn happy but worried it will pop up again
Andrew6.688
Dec 13, 2015 10:59 AM
GVMV
Aug 16, 2015 08:01 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
