Fuel lines
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Fuel lines
I need to run lines to stock tank front to back, Options? should i just get a coil and do it myself or find prebent?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Fuel lines
whats wrong with the stock lines? if you run flexible lines all the way, be aware some sanctioning bodies require you to limit the amount of rubber in the fuel system. theres a flexible line that i think doesnt count towards that amount though.
Engine: 357
Re: Fuel lines
I have no stock lines. My car was gutted when i got it
Transmission: 4L80E/4L80E
I've got a set of factory lines that are in good shape, but in order to get them to you, they would have to be coiled up.
I'd get a coil of aluminum fuel line and run my own. Wait, that's what I did...
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
