Carbed LB9 - Modifications for Autocross
Car: 87 IROC
Engine: LB9
Axle/Gears: 3.70 9 bolt
I'm looking into options for building up my 305 for autocross and weekend use. My goal is to make the flattest hp and torque curves I can get and also to find a good sweet spot for the car. By sweet spot, I mean running around 3000-4000 rpms in 2nd gear around the cones. I'm not concerned with fuel economy.
The car:
87 IROC
305 LB9
T5 (M39 with .63 5th gear)
G92
hardtop
Current mods (all by previous owner):
Holley 600cfm carb from 1970
Performer RPM intake manifold
Crane Ignition box
Accel HEI distributor
!A/C
!Smog
Rebuilt original 9 bolt with new posi cones and 3.70 gears
LS1 brakes front/rear
Koni yellow shock/struts
UMI camber plates
Adjustable panhard bar
Aside from changing the intake and ignition, the motor is original. If the car was still TPI, I'd have a better idea of what to do but this carb swap is throwing me off.
Any thoughts? I need the most input on a cam and heads because i already have a plan for my full exhaust. Is the Performer intake limiting?
The car:
87 IROC
305 LB9
G92
hardtop
Crane Ignition box
!A/C
!Smog
UMI camber plates
Transmission: 4L80E/4L80E
I'd say show up at the PO's door with a crowbar and beat the TPI system out of him.
Car: 87 IROC
Engine: LB9
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Car: 87 IROC
Engine: LB9
Re: Carbed LB9 - Modifications for Autocross
Long story short, it runs but it's a mess. I will be re-doing all the lines soon. The easiest way would be to just use the mech pump that it's running on now, but I was thinking I may just get a new in-tank stock pump (it's like $52) and hook that back up with the Mallory 4309.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
No ones going to be able to to give any good feedback without knowing what class you plan to run in. But the fact that you changed the intake alone means that you at least be in ESP.
Car: 87 IROC
Engine: LB9
Original owner changed the brakes and removed A/C, smog, rear seats etc. so automatically I'm in CP. Which sucks because the drive train is stock. So cam and heads suggestions that are compatible with this Holley and RPM intake would be appreciated. Thanks.
efiguy
Sep 27, 2015 01:30 PM
Damon
Sep 26, 2015 04:29 PM
