Vaccum to mechanical?
Old Mar 15, 2012 | 04:15 PM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
I have a holley 670 street avenger carb. I only put 5-6000 miles on it and now im going to a manual trans. Is there a cheap way to convert it to mechanical secondaries or so i have to shell out another 300 for a Holley 650dp.
Engine is a 355 making around 380hp.
Old Mar 15, 2012 | 04:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Vaccum to mechanical?
You'd have to replace it, but nothing's stopping you from using a VS carb with a manual transmission.
Old Mar 15, 2012 | 04:21 PM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
So do you think that if i just put in the stiffest spring for most the most throttle response the carb will run fine with the stick shift?
Old Mar 15, 2012 | 05:22 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The deal with vacuum secondary and manual trans is that you lose some response, and especially so the slower you shift under load. A very good driver may loose only minimal performance between shifts, but a bad driver could loose a lot.
If best quarter mile times are a must, then it make sense to switch to the manual secondary carb.
If 0.1 - 0.5 tenths of a second isn't going to matter to you, then don't worry about it.
Yes there is a way to convert a vacuum secondary to manual operation, but without the benefit of the second set of squirters (accel pump) there is the likelyhood that you could create a bog under certain driving situations.
A very good driver & tuner can make it work, but getting max performance using the wrong parts isn't always easy.
Old Mar 15, 2012 | 11:03 PM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
Alright thanks for the quick responses. So I will probably just run what I have for the year and next year when I can afford better gears in the rear and, will be more concerned with track times then, i will buy a new carb.
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
