Holley help
Old Mar 20, 2012 | 03:56 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Holley help
I have a 6210 holley, Yesterday was the first time I started it up, since October. It idled fine for about 20 minutes. I shut it off and when I restarted it, it was idling badly, Very low and belching black smoke. I figured it was a fluke, and put it back in the garage. This morning I went to take it for a ride, and it was doing the same thing, I pulled the aircleaner and I had fuel spitting from the secondary boosters. Any Ideas?
Old Mar 20, 2012 | 05:19 PM
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
Re: Holley help
sounds like the secondary float is stuck.
Old Mar 20, 2012 | 09:12 PM
spud's Avatar
Engine: 400 & 355
Re: Holley help
Well the wife took it to work any way, and when she got home it was running fine. She said after about 20 miles it smoothed out. I will pull the bowl and check for dirt in it.
Old Mar 20, 2012 | 11:58 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Holley help
Make sure you pull the needle and seat out of the bowl too, and check those. Sounds like there was a bit of crud propping it open that eventually passed thru, but there may be more. Might behoove you to check the primary side too, transfer pipe, inlet, and filter.
Old Mar 21, 2012 | 06:51 AM
spud's Avatar
Engine: 400 & 355
Re: Holley help
Good plan, Thanks
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
