carb swap question
Old Apr 1, 2012 | 11:13 PM
neverfinished88's Avatar
Car: 88 Camaro
Engine: 5.0
Transmission: 700r4w/shift kit
Axle/Gears: 10 bolt
carb swap question
i have a 88 camaro and was just wondering if i can run a mechanical fuel pump or do i have to get the regulator and run it that way if can run it either way what would be the best and cheapest way to go
Old Apr 2, 2012 | 01:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The in-tank electric pump either needs to be operating, or it needs to be removed.
Old Apr 6, 2012 | 10:34 PM
Car: 88 Camaro
Engine: 5.0
Axle/Gears: 10 bolt
Re: carb swap question
ok but can i run a mechanical fuel pump off the side of the block
Old Apr 6, 2012 | 11:39 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Im pretty sure your block will have the provisions but your cam probably doesnt have the lobe to use a mechanical pump.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
