Switching from a LG4 carb to a H.O. carb.
Subscribe
May 4, 2012 | 02:55 PM
Could I just switch a LG4 carb for a H.O. carb without redoing anything else or do I have to mess with the ECU or anything else?
Reply 0
May 4, 2012 | 03:23 PM
Re: Switching from a LG4 carb to a H.O. carb.
By H.O. you mean L69? They're essentially the same.
Reply 0
May 4, 2012 | 03:44 PM
Oh are they so I don't need to change anything then right? (I am considering buying a L69/H.O. for my Camaro)
Reply 0
May 4, 2012 | 03:47 PM
Any differences between them are fairly minor.
Reply 0
May 4, 2012 | 04:14 PM
Install a set of DR seconday rods on a J hanger and PRESTO! You have an L69 carb. There are no other differences that I'm aware of.
Reply 0
May 4, 2012 | 04:33 PM
Quote: Install a set of DR seconday rods on a J hanger and PRESTO! You have an L69 carb. There are no other differences that I'm aware of.
Oh I don't actually have an LG4 in my Camaro. It has a 350 with an LG4 carb.
Reply 0
May 5, 2012 | 01:55 AM
Quote: Could I just switch a LG4 carb for a H.O. carb without redoing anything else or do I have to mess with the ECU or anything else?
Quote: Oh I don't actually have an LG4 in my Camaro. It has a 350 with an LG4 carb...
... so lets clear everything up, your running a stock LG4 carb on a 350 w/the LG4 ECM controlling spark advance?
Reply 0
May 5, 2012 | 01:56 AM
Haha. Wow, if you are then you are limiting that 350 BIG TIME.
Reply 0
May 5, 2012 | 07:24 AM
Quote: ... so lets clear everything up, your running a stock LG4 carb on a 350 w/the LG4 ECM controlling spark advance?
Yes I am. Some previous owner dropped a late 60s-early 70s truck motor in it.
Reply 0
May 5, 2012 | 07:25 AM
Quote: Haha. Wow, if you are then you are limiting that 350 BIG TIME.
How all of the aftermarket carbs are rated at 600CFM and from what I have read the stock Q-Jet gets 600CFM stock and you can get it to do 700CFM.
Reply 0
May 5, 2012 | 08:50 AM
Quote: Yes I am. Some previous owner dropped a late 60s-early 70s truck motor in it...
Then you need better rods w/hanger, and an L69 prom (has a much better spark curve)...
Reply 0
May 5, 2012 | 11:13 AM
Not so much.
Reply 0
May 5, 2012 | 02:50 PM
NOT AT ALL...The 70s smog heads and tiny stock cam are choking that 350. If it still has the LG4 exhaust its even choking it worse.
Reply 0
May 5, 2012 | 04:53 PM
So new exhuast, heads and cam will really breath some new life into it?
Reply 0
May 6, 2012 | 12:05 AM
Yes
Reply 0
May 6, 2012 | 12:07 AM
Ok, my bad. Whenever I think of someone dropping a 350 in. I don't assume it's a stock 350 with smogger heads. To me that wouldn't even be worth the time.
Reply 0
May 6, 2012 | 12:18 AM
Even if it wasn't a smogger, a Qjet will happily feed just about anything you'd want to run on the street.
Reply 0
May 6, 2012 | 12:20 AM
Well, I am not going to get into that argument.
Reply 0
May 6, 2012 | 11:22 AM
Quote: Ok, my bad. Whenever I think of someone dropping a 350 in. I don't assume it's a stock 350 with smogger heads. To me that wouldn't even be worth the time.
I know I am not the one that put it there, but even if it had nice heads the Q-jet would still feed it just fine.
Reply 0
May 7, 2012 | 04:17 PM
FYI, my 400hp 12 second 350 LG4 (was a 305 obviously) is not being limited by the carb, but by the heads and cam. So anyone who tells you it is a limiter until at least 450hp is blowing smoke up your buttski. Assuming the carb is working correctly.
Reply 0
May 7, 2012 | 04:19 PM
The carb is going to be rebuilt
Reply 0
Subscribe
