Carb spacer for more top end? help me out
Old Jun 17, 2012 | 01:00 AM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
hey guys im running a holley 600 cfm 4 barrell with vac advance sitting on a weiand stealth dual plane intake. (divided in the middle)
Im looking to increase mpg and top end. My car tends to fall on its face, but its got decent low end tq.
The engine is a early 90's 350 with just bolt ons.
What kind of spacer/ and size would u use and why?
I cant decide between a divided spacer, 4 bore spacer or open spacer.
Any help/ suggestion appreciated
Old Jun 17, 2012 | 01:08 AM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Re: Carb spacer for more top end? help me out
Well typically a spacer will add more air volume in-between the valve and the throttle blade moving the power band up a little bit however it doesn't really do anything for performance because the same amount of air is getting in your just making power at a different time
Old Jun 17, 2012 | 01:16 AM
Car: 1986 Iroc-Z
Engine: 355
hmm i see makes sense. Well i would definetly like to move the power band up, with my current set up what spacer would u use?
Im also looking to keep the carb cooler so the fuel wont get as hot. Ive heard that just that would give some gains.
Old Jun 17, 2012 | 01:34 AM
Car: Camaro RS
Well if you got one I would get the one that has the smoothest connection to what you have so no lips will be obstructing flow and don't worry about the spiral flow ones and their shenanigans. As for the carb cooler, is it just a cool can for the fuel line or what do you have? The cryo bars look pretty cool but iv'e never had one
Old Jun 17, 2012 | 02:02 AM
Car: 1986 Iroc-Z
Engine: 355
i dont have anything right now specifically for keeping the carb cool.
I figured the spacer might act as a cooler of sorts by seperating the carb from the intake and freeing up some hp.
Old Jun 17, 2012 | 10:36 AM
Car: Camaro RS
Well if its aluminum it will sink just the same heat into it maybe a plastic or some other composite one would help cool it but in reality its right ontop of the motor so its gonna get hot eventually.
Old Jun 17, 2012 | 11:35 AM
makaveli09's Avatar
Engine: 350sbc
Transmission: TH700R4
i would get a phenolic spacer. you can get the 4 hole one as its better for torque.
but the divided one would work as well.
Old Jun 17, 2012 | 11:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Forget about a spacer, change the heads and cam.
Old Jun 17, 2012 | 02:23 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Or port and polish.
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
