help me find the right quadra jet
As of right now my 87 iroc is carb-less... I am really broke and heading to junk yards for a quadrajet to rebuild. My dizzy is not the original one, so I am looking for a non cc with electric choke and a spot for tv cable
So I am hoping someone has advice on finding one
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: help me find the right quadra jet
Any 74 (?) and up quadrajets should be what you are looking for. Almost any vehicle GM made came with them. You'll want to shy away from Buicks or any other straight inlet quads.
I'd go hit up the F-Bodies and the trucks. Just make sure it isn't a feedback carb.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
One thing that you probably already know spaigo, is to make sure and order a float with the carb. kit. It is a separate item.
Transmission: 4L80E/4L80E
If the computer harnesses are still there, you might as well get a computer carb and distributor while you're at the JY. Much more likely to have a desirable outcome that way.
Finally had time to install... car starts up now but took it around block when I tired giving it alot of gas it about stalles out and I pretty much lose brakes completely... please someone help... the quadrajet is out of a 73 vette could it be cause rods r to small or jets to big? If so why does it cause me to lose brakes?
Sounds like the real problem with your car isn't the carb at all, but rather, fuel delivery.
Put your old carb back on and try a new fuel pump. About $10 and 5 minutes to replace if you're slow like me; more like 2 if you're more like normal people.
86CamaroDan
Sep 29, 2015 10:08 PM
MikkoV
Sep 9, 2015 04:25 PM
