Holley 3310-3
Old Jul 10, 2012 | 10:58 AM
faqz09's Avatar
Holley 3310-3
I am a newbie so please excuse the probably obvious questions. Someone gave me a holley 3310-3 and told me it may or may not need a rebuild, when i slapped it on the truck (4.3L 1986 Chevy) wouldnt crank, i am on planning a 350 swap and this carb would be ideal...now my question is would the carb be able to supply with stock fuel pump? My guess is maybe not, and if so i will get the carb rebuilt
Old Jul 13, 2012 | 11:17 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Holley 3310-3
Those carbs only need 6-7 lbs to work.
On a 4.3????? What fuel pump are you using
I would absolutely throw a refresh kit on any carb thats been sitting. The gaskets shrink after being dry awhile and can leak once you start using them.
Kits are cheap check Summit
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
