new cam, new carb, new dist. wont start
Old Aug 14, 2012 | 06:15 PM
thegoon1969's Avatar
350 v8 with a fresh cam, intake and carburator. distributor is installed at 0* base timing. wires are routed correctly. the car will crank and crank and not fire. if i give it a little gas then crank it the car will fire up and immediately die. I bottomed out my min idle screws then backed them out 1 1/2 turns (thats where the min idle is currelty set) any ideas? Is my min idle set to low?
Old Aug 14, 2012 | 06:35 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: new cam, new carb, new dist. wont start
Open the idle screws a little more and try moving the distributor around a little.
Old Aug 14, 2012 | 06:52 PM
makaveli09's Avatar
Engine: 350sbc
Transmission: TH700R4
sounds like bad timing.
Old Aug 14, 2012 | 07:08 PM
i went out another 1 1/2 turns on the idle screws (now 3 turns out total). car started ran for 8 seconds at low low idle then died. now it wont restart and my battery is dieing
Old Aug 14, 2012 | 08:18 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Get a battery or charger. Put your base timing closer to 15 degrees advanced. Verify spark. Verify fuel. Then crank away.
Old Aug 14, 2012 | 09:43 PM
5spd-iroc's Avatar
Car: '85 iroc-'13 powerstroke H&S tuned
Engine: 406 sbc full roller
Transmission: t5 soon to be t56
Axle/Gears: stock
Are your floats set correctly ? Do you get any fuel out the squirters when you hit the throttle. Sounds like more of a fuel issue, like above verify fuel and try moving the dizzy a bit when cranking
Old Aug 14, 2012 | 10:49 PM
Yes sir i get fuel squirting out when i hit the throttle. The carb is fresh back from being professionally rebuilt. i talked to the guy that rebuilt it he said it was bolt on and go. but you know how that goes. i am charging the battery right now as soon as im done i will put it in and verify the float levels are set correctly.
before i drained my battery i lost spark to the plugs (i verified this with my little Lisile tools "spark tool". I was watching the spark when i was cranking but the last time i put the key in turned it to crank it, the spark fired once and then that was it. the car kept cranking (labored cranking due to the discharged battery) but no more spark. whats up with that? dizzy is brand new, cap, coil brand new all MSD. whats up with that?
Old Aug 15, 2012 | 03:40 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You'd be surprised what some of those performance ignition parts are good for... which is nothing.
Primarily I've had TERRIBLE luck with Accel ignition modules. I finally went to a stock Borg Warner one for $20 and it's been fine ever since. But Ive heard the same complaints about MSD. The dizzy, wires, coil, etc are most likely fine, but the modules were always the parts that gave me fits. So do you have another stock one around you can swap in? If not just ignore that for a while and keep it in your back pocket. It's PROBABLY fine, but you just never know. Its all made in china these days anyway.
Also, I assume the plugs are new? I used some old plugs in one of my builds and they caused a ton of issues. I had an engine I put together and had issues with a cracked block, finally got it back together around a year later when my heart was back in it again and it wouldnt fire. Got some fresh plugs and it was fine. The old plugs looked okay, just sat out in the garage for a while and I guess they just got a little oxidized and/or dirty.
The last thing is, I used some "build em yerself" plug wires once, and maybe even with new already made wires, make sure the contact in the plug boot is snapping or at least fitting agaisnt the plug tip well. With mine I had to squeeze the contacts around each plug tip with some channellocks to get them to make good consistent contact.
You may be losing spark because you're draining the battery.
Whenever it doesnt start, spray some carb cleaner in it and see if that fixes it. Also I would advance the timing a tad. I could never quite get my setup to run with zero base timing. It may like between 10-20 base timing. Higher base timing will make the engine idle higher too, so if the carb is baselined, the choke is off, and you're just trying to get it to kick over and its gurgling at a really, really low idle for a second, kick up the timing a tad and it will build more cylinder pressure and keep it running.
And lastly, if this is a cold engine with new parts... dont expect it to idle right off the bat. You'll need to hold the throttle open to keep it running. Just let it run a few minutes and then set hte curb idle screw to the lowest RPM you can make it run at. Then start tweaking things from there. Get your timing right, get your idle mixture screws right... etc etc.
Sounds to me like it's really, really close to running right.
Old Aug 15, 2012 | 06:13 AM
5spd-iroc's Avatar
Axle/Gears: stock
also if its a fresh cam i wouldnt worry about it idling i would get it to 2000 or whatever the cam card has for break in on it for whatever time usually around 20 min so you dont wipe the lobes off it, if using a roller cam then disregard
Old Aug 15, 2012 | 06:29 AM
Car: 1992 Camaro RS
Definitely. If its a flat tappet you need taht thing rotating at 2k-3k RPMs and covered in oil for at least 20 minutes before you ever let it idle.
Old Aug 15, 2012 | 08:24 PM
I got it a little bit more figured out. its not a fuel issue its a spark issue. when i plug my spark plug light tool inline with the number 1 plug wire and turn the key to crank the motor. The light on the tool only lights up once then it doesnt light up anymore durring that cranking cycle. Pull the key out and try again it does the same thing. lights up once then no more spark. the distributor is new and i just swapped in a new coil to no avail
Old Aug 15, 2012 | 09:45 PM
5spd-iroc's Avatar
Axle/Gears: stock
Check the wires going into the dizzy and make sure its hot with the key on and while cranking if I remember right it the pink wire but not positive on that
Old Aug 16, 2012 | 06:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't seen any details regarding the new parts, like the brand/type of distributor.
Remember how an ignition coil works: A magnetic field is created by electrical voltage on the primary windings. When the voltage is removed, the magnetic field collapses, and imparts a much higher voltage on the secondary windings. It's the removal of the voltage on the primary windings that causes the spark. What I would suspect is happening is the voltage is on when you turn on the key, then when you go to start, you aren't getting the voltage cycling anymore. That could be either a fault in the power to the coil, or a fault in the triggering system in the distributor.
Old Aug 16, 2012 | 06:49 PM
Edwardgp's Avatar
Engine: 454-350
Well how is this project going?
Old Aug 16, 2012 | 07:07 PM
got it started. problem was that i was that during cranking my voltage at the distributor was droping to 8 volts. I ran a wire strait from battery to distributor and it fired right up. now it wont turn off unless i pull the distributor wire from battery. weird though becasue i have an electric fuel pump that turn on and off with the key on and off so i would think lack of fuel pressure would shut the motor down but nope it still runs like a champ.
Old Dec 8, 2012 | 04:26 PM
Yellow3gZ's Avatar
could try running that hot wire that you have going to your battery to your ignition harness for switched 12v power with the key, I beleive it is also a pink wire in the ignition harness you can just use a test light to find it. that way it goes on and off with the key.
Old Dec 8, 2012 | 06:34 PM
bigbubba1488's Avatar
Car: 88 Z28 Sport
Engine: 350 TBI
My old 85 did the same thing. I actually found out that my ignition control module was bad too it into autozone they tested it and gave me a new one for like 40 bucks. Hope it helps
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
cstrobel65
Aug 15, 2015 10:19 AM
