idle problem
Old Aug 27, 2012 | 09:40 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
idle problem
hey guys
so i recently rebuilt my carb bought the kit did the Gaskets and junk then sent it out to a shop my buddy owns that was able to do the solenoids and lower body (throttle went bad) so after putting it back in i noticed the car handles a lot better and no more sticking throttle. but now i also seem to have a nasty vacuum leak, i also noticed it sputters too when at idle at a stop light or when in park. but more over i constantly have to adjust the idle. one day it will be at 500 or 400 RPM (very low) adjust to 600-700 RPM and set for the day, in another day it will jump from the cushy idle i set to 1,000 RPM! so im always driving with a wrench. i don't know what to do any more so i really need the help!
on a side note to i also notice my Check Engine Light come on occasionally while driving only to go off a few seconds to a minuet later. i don't know whats causing it but any ideas truly do help
thanks!!
Old Aug 28, 2012 | 12:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Retrieve the trouble code(s) being set to at least find out what the computer thinks the problem is.
If you have a nasty vacuum leak, that needs to be fixed before you can expect the car to run correctly.
Old Aug 29, 2012 | 09:44 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
Re: idle problem
yeah, i asked at my neighborhood auto parts store and the immediately called lout the O2 sensor, i took it out the whole thing was covered completely in soot, really bad too. so i put the new one in and kept the old one. but the light still comes on. as for the vacuum leak, i have a feeling i know what it is now and will get on it, but i still need help with that light
Old Aug 30, 2012 | 06:28 PM
five7kid's Avatar
It isn't unusual for the O2 sensor to be covered with soot.
A vacuum leak can cause an O2 sensor error code. Get the leak fixed, see what happens.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
