edelbrock or holley?
Old Sep 14, 2012 | 08:25 PM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
i got a street car, headers and .480 lift cam 110 lsa. so i dont need a nice fancy carb. im new to carbs so i dont know everything about them, my friend gave me a edelbrock 1405 for free. i rebuilt it and it had a vacuum leak somwhere. a huge vacuum leak. so i got a used holley from another friend and the car runs a hell of alot better, it wouldnt stay running with edelbrock but i sprayed starting fluid on bottom of holley carb and it revs up so its got a small vacuum leak. im just gonna but a new carb now but whats better a holley or edelbrock? i pick between these two cuz thats all they got at part stores around here and are only a couple hundred. ive heard edelbrock use cheap metal but r easy to tune and holley r real a real bitch to tune and keep tuned.
Old Sep 15, 2012 | 01:56 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: edelbrock or holley?
I have my best luck with holley style carbs. The one thing I don't like about Edelbrock carbs is getting the car started after the motor has been hot. I have heard this is because AFB carbs turn to boil the fuel out of the bowl, not sure if that is accurate a
I know is it does it on my truck, my dads truck and my first create motor.
Old Sep 15, 2012 | 03:28 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
My fuel boils in my Holley. Its a problem that some people have, and some people dont. Definitely not Edelbrock or Holley specific though.
Old Sep 15, 2012 | 04:16 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Quadrajet is better than both Holley and Edelbrock. You'll get the same power numbers with better mileage.
Old Sep 15, 2012 | 05:35 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
The Q-jet is a great carburetor.
Old Sep 15, 2012 | 08:07 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
get a quadrajet from a late 70's pickup and rebuild it.. if you've got an auto trans, make sure the carb comes off a truck with a TH350 trans so you have a place to hook your tv cable. if you've still got the stock computer controlled distributor, steal the vacuum advance distributor out of the same truck and throw a couple of lighter springs from an aftermarket advance kit in it to speed up the advance curve a bit- but keep the stock weights.
Old Sep 17, 2012 | 07:39 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Possible the intake in leaking? If its revving up when you spray either carbs base i would suspect the intake unless you used the same gasket? I always had issues with edelbrock carbs a fuel boiling holleys are a bit better since the bowl is above the intake so has some room to let air around it but they can do the same. It sure is nice to never have to mess with my q-jet havent touched it in 4 years
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
