Pics on Mallory #4309 installed
Old Sep 9, 2008 | 11:51 AM
HottestZ28's Avatar
Does anyone have pictures of this FPR installed and what you used as far as fittings to make the install.
Looking for a clean install or nice looking set-up
car is a 1987 camaro 2.8 => carb'd 350
Old Sep 10, 2008 | 11:56 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Re: Pics on Mallory #4309 installed
Not the best pic, this isnt the cleanest install, but was easy to hook up. I cut the 2.8 rubber fuel lines, and installed 3/8 barb to 3/8NPT fittings for the feed/ and a 5/16 barb to 3/8npt for the return. I used similar fittings for the feed to the carb/nitrous and installed a pressure guage on the last open port. Im running a 255lph fuel pump, and the regulator does a pretty good job. Fuel pressure is a bit high at idle at 7psi, but at WOT it drops to 6 and holds steady. This winter I will probably install a 3/8th return line to help hold the same pressure at all time.
Old Sep 11, 2008 | 11:10 AM
HottestZ28's Avatar
I don't think I have the same set-up. my fuel lines are bent in a 90 then saginal ended.
I think I might do this for a set-u run the 5/16 line up and flare it to a 3/8 NPT return, then run a 90 down from the front port and run a flare/NPT on that as well, then run a 3/8 NPT barbed end and go hose to the feed line to the carb
I'll get pics this weekend if it works the way I am hoping/planning it will
Old Sep 22, 2008 | 03:18 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Old Sep 25, 2008 | 04:51 PM
nut's Avatar
nut
Car: 88 Z28
Engine: Vortec 350, LT's
Axle/Gears: 2.73 posi.
Originally Posted by LilJayV10
Could you make a list of the fittings you used to make that work with stock lines?
Old Sep 25, 2008 | 11:39 PM
LilJayV10's Avatar
Engine: 406 Roller
Yeah let me see if I can get the part numbers.
Old Sep 26, 2008 | 06:32 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
wow im moving mine there instead of on the intake, now i only have to run one long line. nice
Old Sep 27, 2008 | 02:23 AM
LilJayV10's Avatar
Engine: 406 Roller
Thanks you. It could have been a little cleaner. Instead of having the return line loop around it could have been made with a 90 off the side and a straight shot to the return line, might have had to use a 45. My wife did it so I felt it was best to leave it be.
Old Sep 29, 2008 | 12:41 PM
LilJayV10's Avatar
Engine: 406 Roller
Earls part #'s
Fuel line
9894DBJERL
Female 16mm X 1.5 Saginaw
Return line
9894DBHERL
Female 14mm X 1.5 Saginaw
Those are really the only two special fittings.
Everything is just a 90 or a 45.
Sorry it took so long for me to get you the part numbers.
Old Sep 29, 2008 | 01:30 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
what kind of an fittings do u need? i gotta swap mine over from rubber to braided to pass tech you can only have 12 inches of rubber fuel line. Plus it just looks cool
Old Sep 30, 2008 | 03:15 AM
LilJayV10's Avatar
Engine: 406 Roller
The two fittings that I listed are what you need to go from the factory fuel lines to -6 AN fittings. After that its up to you how you run the lines to the carb and the return line. It's kinda of a pain but not bad. I don't think it's a real good idea to run rubber line with the higher fuel pressure of the TBI and TPI pumps. I guess you could use the high pressure fuel line and double clamp everything.
Old Sep 30, 2008 | 07:13 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
but what kind of an fittings do u need that plug into the mallory to the braided line? the rubber line has been holding up fine but time for an upgrade
Old Sep 30, 2008 | 02:03 PM
Demon355's Avatar
My regulator is in the same spot on my 383. Pictures are kinda shitty and my engine bay is really dirty. I haven't had the time to clean it as the motor just went into the car.
Old Sep 30, 2008 | 02:16 PM
LilJayV10's Avatar
Engine: 406 Roller
You will need a 3/8 NPT to -6 AN fitting on the regulator.
Old Sep 30, 2008 | 03:15 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
I am currently in the middle of my fuel line project. If anyone is interested I have pics of the fittings and part #'s that will allow you to go from the injector pod to the factory flexible lines or if you desire to go directly to the hard lines
Let me know
Old Oct 5, 2008 | 09:43 AM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Great post. I bookmarked it since I intend on doing a carb swap on 2 vehicles. lol
Old Oct 7, 2008 | 05:17 PM
HottestZ28's Avatar
Yea I am completed running the fuel lines and have 2 questions-
I ran it as follows ->reg mounted to strut tower bolt, bent the factor lines to regulator, flared stardard 45 flares. Ran the return through the bottem and the feed to the front most port through a 90 fitting. The ran thee port facing the motor to the fuel inlet of the carb. Blocked the other 2 ports.
now for the questions
#1 Do i need the "madatory" fuel filter between the reg. and carb? Holley 4160
#2 Does anyone esle adjust their pressure to around 6 psi and get a bouncing needle(fuel gauge) and line problem? Now the only thing i am thinking is if, lets says the return line is clogged then you would think it would bounce more when "more" fuel is returned at a lower PSI not at a higher psi or is the fuel PSI gauge wrong that is in the Y-block for the dual feed in the carb?
Old Nov 1, 2008 | 11:11 AM
69442DREAMCAR's Avatar
Let me know
DCtrumpet, please email me at chandler738965@bellsouth.net
Old Dec 30, 2008 | 10:06 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
This is how I have it now as you can see unsafe and ugly. I am going to mount it by the two hard lines. Double clamp rubber hose to the hard lines and run a 3/8NPT to -6AN fitting to -6AN braided hose to the carburetor fuel line inlet. I have that blue jegs carb line with the gauge does anyone know what fitting I need for that? Also If I have a regular fuel filter (under the car) and fuel filters in the carb bowls do I still need yet another fuel filter in between the regulator and inlet?
Old Jan 1, 2009 | 05:02 PM
ruiterman's Avatar
Car: 91 Z28, 89 Formula, 85 IROC Z28
Engine: 305 TPI, 305 TBI, 305 TPI
Transmission: 5 Speed, 5 Speed, 700R4
My son and I did a similar install to what you everyone else did. As you can see in the pics not much different.
I didn't know and couldn't find the fittings to go from the car hardline to the npt so I ended up having a custom hose shop make new hoses using the old fitting on the car side of the lines. Turned out real nice, and cost less than $15 (that's just for those two hoses, not the braided lines and other fittings).
The braided line and other fittings are standard stuff like everyone else is using.
Attached Thumbnails Pics on Mallory #4309 installed-img_0118a.jpg   Pics on Mallory #4309 installed-img_0112a.jpg   Pics on Mallory #4309 installed-img_0117a.jpg
Old Jan 3, 2009 | 12:10 AM
SKYNOVERYA550's Avatar
Car: 88 iroc z28
Engine: 355
Transmission: Bowtie stg 3
Axle/Gears: 4:11
min is pretty simple and clean... sorry about the blurry picture.
Old May 25, 2011 | 05:21 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I just finished reading this and am about to install my 4309 and found this extremely helpful. Thanks guys
Old Jun 25, 2012 | 11:54 PM
shadow315's Avatar
Car: 92 Firebird
I found this old thread to be very helpful and thought I'd add my pic. I borrowed Nut's idea of mounting directly to the return.
Old Aug 14, 2012 | 09:53 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
old thread but VERY helpful
Old Aug 14, 2012 | 12:14 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Very nice setup...
Originally Posted by SKYNOVERYA550
Old Aug 15, 2012 | 07:03 AM
Car: 91RS
got any pics of a edelbrock 1406 carb. setup
Old Aug 15, 2012 | 07:59 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I know this is an OOOOOLD post, but did you (or anyone else with this placement) ever have any issues with fuel boiling in the fuel lines after the car sits when its hot?
Old Sep 7, 2012 | 04:02 AM
Electro Panda's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 327 sbc
Transmission: 400 turbo with Shift Kit
Should a fpr be required with a mechanical fuel pump?
Old Sep 7, 2012 | 06:07 PM
LilJayV10's Avatar
Engine: 406 Roller
Internal,
I haven't had any problem with that setup.
Elcectro,
If you using a big mechanical pump that is putting out more than 7psi you might need some sort of regulator but I don't know how you would return it to the tank.
Old Sep 7, 2012 | 07:29 PM
Engine: 327 sbc
I have a stock mechanical fuel pump and my car drives and idles good but I'm honestly only getting one mpg I figured a fpr would fix my problem. 327 with a edelbrock 1406 (600cfm) Pics on Mallory #4309 installed-ece32a1ef25211e1839c123138192853_7.jpg
Old Sep 7, 2012 | 08:01 PM
LilJayV10's Avatar
Engine: 406 Roller
1 mpg? If that's honestly the case I don't see how the car is even running or how you have rings left.
Old Sep 7, 2012 | 08:19 PM
Engine: 327 sbc
Ok I over exaggerated more like five mpg. The fuel system consist of [tank to mechanical to fuel filter to carb]
Old Sep 7, 2012 | 08:32 PM
LilJayV10's Avatar
Engine: 406 Roller
I would start a thread listing all of your mods and what problems you are having if you haven't already.
Old Sep 7, 2012 | 08:43 PM
Engine: 327 sbc
1989 FireBird was a tpi setup converted into Carb. 327 sbc. Has forged pistons, Stock cam, Edelbrock performer intake, Edelbrock 1406 carb (600cfm), Polished and Ported 305 heads, Steel tubed headers, Accel Distributor. Fuel system uses stock tank with a hose to mechanical fuel pump to Fuel Filter and into the carburetor. Car has AC delete. 400 turbo transmission and the rear end has a 3.27 gear ratio.
Old Sep 7, 2012 | 09:01 PM
LilJayV10's Avatar
Engine: 406 Roller
So we don't clutter this thread up.
Old Sep 7, 2012 | 10:51 PM
Engine: 327 sbc
How do i make a new thread? I'm new at thirdgen
Old Sep 10, 2012 | 12:57 PM
LilJayV10's Avatar
Engine: 406 Roller
What kind of pressures are you guys setting your carbs to? My car is running really bad and I can't track down why yet. I have a cheap liquid fuel guage on my car. When the car warms up the pressure drops down. I don't know if its the gauge or the fuel pressure is actually dropping. The highest I can get it to go is 9psi and the lowest is 5psi. IIRC I am using a TPI pump. I'm going to check the fuel filter tonight and see if its clogged up.
Thanks.
J
Old Sep 10, 2012 | 01:24 PM
Car: 91RS
http://z28boy.cz28.com/
Old Sep 13, 2012 | 12:07 AM
whyt86roc's Avatar
Car: 92 Camaro RS
Engine: 355 L98 Carb
Transmission: WC T5
Axle/Gears: 3.73 Auburn Posi
Here's how I have mine installed... I used the stock hoses and mounted it to one of the bolts on the strut tower mount plate.
Old Sep 14, 2012 | 11:21 AM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
i have one of does too
Old Sep 17, 2012 | 07:54 PM
dangerboy's Avatar
Car: 83 Trans Am
Engine: 350 Carb'd
Does anyone have a pic of their setup on a swap from crossfire injection? It appears to me that the supply line is on the passenger side and the return line is on the drivers side with the line that went to the charcoal canister. Thanks.
Shawn
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
aaron7
Aug 17, 2016 06:02 PM
mustangman65_79
Aug 13, 2015 07:36 AM
sonu1975
Aug 11, 2015 08:38 AM
armybyrd
Aug 10, 2015 09:23 PM
